I have a 2011 Jeep Compass that went into limp mode the other day and the transmission was whining after being on the Interstate for awhile. My engine code says my TCC Solenoid is stuck off. I can't find where that solenoid is. I found one but I don't think it's the right one. Can someone help me locate this so I can change it out? I am also going to change transmission filter & fluid.
I just joined forum tonight. Earlier today I replaced the pressure control solenoid as my code was "stuck open". This solenoids are located inside the valve body. Requires removal of the pan then valve body. There were specific bolts etc that needed removed. I'm no mechanic but after tons of research found a manual that I showed to the significant other, who is a mechanic and he said that was what he needed. I'll include that link for you. Hope it helps.
https://www.google.com/url?sa=t&source=web&rct=j&url=http://aamcoftp.com/sites/aamcotech/assets/cvt-manual_cvt-manual.pdf&ved=2ahUKEwicwfK8iK_lAhXBFjQIHYcMAM0QFjAAegQIBhAB&usg=AOvVaw2wFlbPa0zvdr_Kb7scIzV1
Or you can just Google CVT manual aamco. It's a PDF document
