1 - 16 of 16 Posts
I called Jeep 1-800 number to answer would I would assume would be a fairly easy answer for them. My parents have a Compass, and know their towing capacity is 2000 lbs. I see the payload capacity is 1,160 lbs. I wanted to know simply if we could tow the boat and still have the 1,160 lb payload capacity.
She then proceeded wanting the vin number, I told them I didn't have that. Then she wanted their name and zip. Then I had to verify their address as if I or they did something wrong. She then puts me on hold again and questions me on the hitch, were it was installed and what class and so forth because they didn't have record of it. I'm like you guys sold it to them with it. she then told me the class ratings and amounts you can tow with them. She said it could have from a class 1 to a class 4 with a 10,000 tow rating. I'm like 10,000, she said's yes, I ask on a Jeep Compass, and she said yes. She seriously thinks your going to tow 10,000 lbs with a Jeep Compass. I told her it must be the class 1 because its 2000 lbs they can tow with it. She told me I had to contact the dealership and she didn't have that information.
Seriously? They don't know if its tow capacity plus payload or tow capacity minus payload. But she knows it can tow 10,000 lbs. Like I am going to trust a salesman that didn't even sell them the right Jeep to began with and didn't know the correct options. But I can sure as hell know that If I told them something they thought may have voided the warranty they would let me know then. Here all this time I though GM was bad. Jeep really hires some brain dead people.
So after all that, I'm sure I can get a quick and easy number without sending in a birth certificate and police record to get an answer.
Is the capacity of both the towing and payload, or do I have to subtract the payload from the towing?
Say I want to haul a 2000 boat and a other 1,100 lbs of camping gear and people. or am I over capacity.
towing capacity
It depends, on a lot. Since you not even provided the year, options, power train of the Compass. Its all guess work. 10k Lbs not on this planet period.
A base CVT compass is 1000lbs and up to 2000lbs IF and a big If you have the optional cooling package/option and that is the MAX 2000lbs. having towed a few times I can tell you that wind drag brings it to its knees. A boat is more streamlined so the impact is less and also braking will be a lot longer and harder. You have to adjust you driving habits for sure. 2000lbs is NOT standard. Check your owners manual it will tell you specifics.
Depends on a lot of what? Shouldn’t matter if it’s a 2007 or a 2014. Shouldn’t matter if it’s a 2.0l, 2.2l, 2.4l. Shouldn’t matter if it’s a 5 speed, 6 speed, or CTV. Do you need my blood type too? The color of the Jeep is red if that matters.
In all seriousness, the Jeep lady was provided all this information. Yet none of it is needed for the question to be answered. Year does not matter, engine size does not matter, transmission type does not matter, and nor does my address. Its really not a complicated question here, but I seem to be getting the run around.
The Tow Capacity is Rated 2000 lbs and the Payload Capacity is Rated 1,160. Lets say for fun this is a 1956 Jeep Compass with a blue door on the left and red on the right. It has 1 doom light that weight a half an once. Oh ya, and a electric radio with 8 track player.
Again one last try to clarify it. The Tow Capacity is Rated for 2000 lbs and the Payload capacity is for 1,160 lbs. Does this mean I can tow a 2000lb boat along with hauling 4 people weighing say 720 lbs and another 440 lbs of gear?
Every vehicles owners manual has always cover that scenario. I've been towing for over 4 decades with every type of vehicle. The manual is the definite guide with the facts.
First, I would like to apologize if I came off as a jerk in my prior post. I am having a bad day. Tired of dealing with stupid people all day, and in a extremely whole lot of pain. I know your only wanting to help.
I don’t have the owners manual available. I don’t live with my parents. My father is wanting to take the other vehicle which is a nono at this point. We heard some serious engine noise last time we towed the boat. It happened under load and concerned me. I think I will end up having to rebuild the engine. It may just be something was rattling, but I don’t think that was it. And I certainly don’t think we should be driving the F150 on a long trip with the boat, camping gear, 4 people and a dog on a long trip. And don’t really have the time to rebuild the engine and have it done anytime soon. He’s scared to even tow with the Jeep. This is part of the reason he got the Jeep in the first place. He got the upgraded model that is trial rated with the towing package to handle 2000 lbs. A quick check into it I was able to find that the boat, trailer, sand two motors puts us just shy of 1800 lbs. I’m not sure what all of our gear weighs at this point yet. I will need to find this out. I don’t want to tell him oh yea, its plenty capable of handling the boat and our gear if its not. But I also don’t want him thinking he cant do it if he can. Our trip maybe require 2 vehicles now at this point. Also, even if he is hell bent on taking the Ford, I want to be sure we have a backup plan with the Jeep if needed and not be 700 miles away with a boat and all our gear and no backup plan.
Fare enough DAFLY
Then you should consult it here. Most things can be downloaded. Some dealers service departments also helpful. No guessing though.
Jeep Owners | Download an Owners Manual 2004 - 2011 | Jeep
Good luck.
I'd be concerned about the noise.
NOTE. The towing package has an OIL COOLER & its for the Engine Oil and not the Transmission !!!! Hence using synthetic oil with a quality filter EG Wix (what I use) will help a lot. IMO
Ok as per MY manual this is it. The numbers may change slightly however the computation is the same.
Total Load is = Combined weight of occupants, cargo & Tongue weight of the trailer
Addition roof carriers etc are added here as well.
As for the trailer (in my case 1000lbs) w/max 22 Sq Ft front. If tow prep option then the front increases to 32 sq ft and 2000lbs w/ AC.
They specify not to exceed either the GAWR or GCWR of the vehicle so I guess its possible to affect the towing load with well loaded occupants or chubby ones toating huge purses etc. LOL
I most cases the GAWR will not be exceeded but a well loaded Compass with a trailer appears taxing to the vehicle and the CVT labours at a much higher RPM on the highway almost always. I haven't tow more that 500lbs yet and minimal internal cargo.
In my opinion the cooler is of little necessity when towing in the winter due to the cold hauling snowmobiles for example. However, synthetic oil is recommended (by me) due it superior characteristic when very hot and no sludge risk. The CVT has a cooler behind the rad along the bottom which is standard.
Most people will have a 100-300lb tongue weight depending on the setup since 10% -15% of the trailer weight is shifted to the front for stability. Although no mention is given to climbing hills and/or steep grades. I know from experience this is very hard on the power train. A lower gear selection will help save a transmission and/or engine from overheating.
i cant speak for you guys 'over the pond' but i have a 2.2CRD limited manual which is a 4x4.
all of the towing details are in the manual.
max hitch load is 100kg (220lb)
max towing weight is 2000kg (4416lb) (this is the point the car throws in the towel) the max tow weight is on the cars log book, this is not a jeep document but a uk government department document that is the cars registration)
the kerb weight of the car is only 1680kg (3702lb).
what is not in the manual is that towing safety rules state that the max load for towing is 85% of the cars kerb weight. so a maximum of 1428kg.
my 2.2crd makes 263bhp and 320 NM torque.
i tow a caravan of MRO1050 and MPLM 1280kg (it is never loaded to this though).
my compass can tow it comfortably up to the uk towing limit of 60mph (and more) and deliver 29mpg (imp gallons)
however, you can see that i take it no where near its towing capacity but the caravan can jolt the car around and side winds effect it badly. i guess this is normal for towing something 7m long 2.4m wide and 2.5m high.
i wouldnt want to exceed 85% of the cars kerb weight, it would not be safe in my opinion.
i guess this is meaning less to you guys with FWD and CVT (automatic transmission). i guess the cooling package everyone mentions is for the auto transmission since my car runs at a normal temperature whilst towing.
anyone else in the UK tow with a compass?
Not detail but I am guessing you're in the UK.
The cooler for increased towing is for the engine oil, yes oil. The CVT equipped has a cooler behind the rad at the bottom. But you don't have that in a Manual gear box.
That's a lot of weight. Sway bars are used on bigger trailers and anything over 2000lbs inclusive requires trailer brakes which you're should have even there. You won't stop worth a hoot without them and will definitely end up in a ditch sideways are jack knifed with it pushing you. For proper setup min 10% -15% of the trailer weight goes to the hitch (a must or fish tailing at highway will occur).
Being diesel and manual transmission you're not going to be affect by what we have to do. The north American builds are 1000lbs rated unless the tow package is installed which had the referred to oil cooler giving 2000lb ability. I towed about 600lbs with mine and the brakes are barely adequate and gas mileage drops like a stone. 15mpg at best but likely worst even with an near empty small trailer with minimal wind drag.
1000 lbs towing capacity with out a oil cooler other wise you can tow 2000 lbs
so the only question you have is how much does you trailer weight?
Honestly, in the most of the cases I see petrol and diesel Compasses like two different cars, not only due to fuel differences but the engine designs!
Great post, thanks for sharing it.
That would be a super sketchy tow it seems like, even for the diesel. The rest of the car is not as tough as that motor is. Maybe if you are only going to crawl 15-20 MPH in first gear the whole way, for a very short trip. Your brakes had better be like brand new, hard to stop that kinda weight if you do pull it up to any serious speed. Odds are the tongue weight will simply fold the back of your car in before you get started though, if not then maybe when you hit a good bump somewhere along the journey. Very unsafe idea, very high odds of damaging your vehicle. Some people would do it anyways and maybe even get lucky and succeed but even if the car doesn't break the day you move it, can about guarantee you are significantly shortening the life of some major parts.
1 - 16 of 16 Posts
