1 - 9 of 9 Posts
2010 Latitude, 1st cold morning 30 deg. TPMS light on check tires pres. okay 35 -36 psi, drove to work leave work temp 50 deg TPMS light on recheck tire pres okay, got home let cool down 2 hrs recheck tire with another gauge pres same 35-36 psi I'm original owner 65K miles could this be a bad sensor? Fred
make sure all 4 tires are at the exact same pressure when there is even a 2 psi difference the light will come on.
Not that likely its bad. Was any work done to the wheel (tire change etc). Whenever there is a big temp swing they can go off determining there is a low pressure issue. It may stabilize after some driving, something I have heard they can be temperamental. As long as the pressure is < 5lbs from spec they should not be going off. One tire much lower seems to aggravate the problem. If you verify it with another pressure gauge just wait and not worry. If should clear on its own. Otherwise a software bug, contact the dealer if there is a fix.
Hey Fred,
Unfortunately, I could not locate any TSBs related to your vehicle. I would advise you to have the vehicle checked for stored DTCs at a certified FCA dealership. If you would like me to look further into this, please private message me the last eight digits of your VIN and servicing dealer.
Well here is what I have noticed so far, Had tiers read and all sensors good and transmitting remote start is acting up as is remote lock un lock, and lower dash lights are out were seat warmer buttons are the remote has new battery tries spare remote same problem OBD scan shows no diags. and tire light on steady
Hey Fred,
Things cleared up for a while then yesterday another cold day 15 deg F, tire light on snows on now been on for 2 months, no remote control in am works fine rest of day, worked this morning 20 deg's but no radio volume can change chanels but no vol. or vol level display I think car is hinting to be replaced.. LOL
and buy the way tire light on again, and last week gas cap light came on and cap was okay light off in 2 days
Hey frediefreon,
As I stated in my last post, I would advise you to have the vehicle scanned for stored diagnostic trouble codes. These can codes provide brief descriptions of the illuminated light, and can possibly lead to a diagnosis of the vehicle.
1 - 9 of 9 Posts
