The TPM system consists of tire pressure monitoring sensors attached to each road wheel through the valve stem mounting hole, a wireless control module (WCM) three wheel sensor transponders located in three of the four wheel wells, an electronic display, and an indicator lamp.
The receiver circuit for the TPM system is integrated into the WCM. Commonly referred to as the Sentry Key Remote Entry Module (SKREEM), the WCM also includes the Remote Keyless Entry (RKE) receiver and the Sentry Key Immobilizer (SKIM) receiver. All three receivers share a number of common components. The WCM decodes the RF signals transmitted by each of the vehicle’s tire pressure sensors. The decoded information is used to determine if "warning" or "fault" conditions exist within the TPM system.
Upon detection of a warning or fault condition, the WCM will send a request to the module that controls the indicator lamp (and the text display if equipped with the Premium system) via the vehicle bus system to illuminate or flash the indicator lamp. Also, upon detection of a warning or fault condition, the electronic display will send a request to sound the "chime". A chime will only be requested once per ignition cycle per warning or fault condition detected.
The WCM will store all warning and fault conditions, placard pressure values and low-pressure threshold values (lamp ON and OFF) in memory that can be accessed through diagnostic communication. If new sensors are introduced to the vehicle, the data stored for the sensor being replaced will be deleted.
The WCM will store all wheel sensor ID’s and locations and faults in memory that can be accessed through diagnostic communication. All other data values transmitted from each active wheel sensor (not the spare tire) shall be stored in the WCM memory.
The WCM automatically learns and stores the sensors’s ID while driving “within 10 minutes continuously above 15 mph (24 km/h)” after a sensor has been replaced. The learning sequence will initiate when the vehicle has been stopped for more then 20 minutes.
