1 - 9 of 9 Posts
I have a 2011 jeep compass and i was cleaning the air intake sensor when i noticed the transmission dipstick tube was broke off and leaning up against the back of the fans. Anyone else have this issue? Is it an easy fix or is it something that a dealer has to fix? What was the cost?
It could be a factory defect. I've heard of it happening in Wranglers and compasses before. Best to see if it's covered by the dealership or get a quote from a trusted mechanic.
My 2012 Jeep Compass had same problem today! It broke off! I bought 7 years extended warranty, does it covered? thanks! Any one know?
I don't know about the extended warranty.... you may call to find out?
I just had the same issue with my 2012 Compass @ 48.800 miles when I noticed a rattling chain-like noise coming from underneath, finding a broken-off part sticking out from the engine protective shield scraping along the concrete driveway!
Dealership says it's not unheard of and happens quite often, warranty expired @ 36000 miles; labor cost will be around $130 +- plus part (FYI: tube part MOPAR 05273372AF - Tube costs ~$25 +- on Amazon, APSG CAP/COVER - Screw On Transmission filler seal cap is another $10 if you lost it).
No idea how long it actually has been broken off and laying on the shield until it found it's way into one of the ventilation slit.
I called the Chrysler assistance center: no recall, not heard of or logged in their system :surprise: (! - although you find same issue @ Jeep Patriot forum Dipstick Tube Breaking grrrrrr
Not only shouldn't the metal part just break by itself (IMHO it's a flawed design that snaps off at the bracket under normal engine vibration), it can cause fluid contamination etc..... another expense to get it exchanged!!
I was going through the bank drive thru, and heard a pop, then like a chain rattling, I pulled over but didn’t see anything. Got home and I seen the pipe hanging down on the pavement, That should be a recall!!!!
Since these are 2011/12' Compasses, I'm assuming that they have the CVT automatics in them? If that's correct, what year did Chrysler/FCA start putting trans dipsticks on the CVTs? My 2008's Jatco CVT trans is sealed, from what I can tell. Just curious. Thx.
-CSM
I have the same problem. 2012 Compass. CVT fill tube is broken off. I wanted to try and replace it myself. I have the parts, but not really sure where to start and if I should even bother. Anyone try doing it themselves?
1 - 9 of 9 Posts
