Hi
Picked up my 2018 Compass last week and very happy with it so far.
However, I have noticed a few odd things with my uConnect system which I wondered if anyone else had come across?
1. I turned off all the POIs and cameras in the NAV which was fine for a couple of days but the cameras have now come back on and I cannot turn them off
2. Whenever I am on the map view and am driving it zooms in every time I come to a roundabout. It didn’t do this to begin with but now does it all the time and I cannot see how to turn it off
3. The climate control temperatures have reset themselves a couple of times from what I set them to back to what they were when I first got the car
Any thoughts?
Thanks
Rog
Hi
Any thoughts?
Thanks
Rog
Hi Rog,
I can understand why this would be frustrating. Are you planning on making your dealer aware of what you're experiencing? Send me a direct message as I'd be glad to get this escalated to a Case Specialist for further handling.
Jasmine
Jeep Social Care Specialist
Hi Jasmine
I cannot PM you as I do not have enough posts yet...
I did contact the dealer but they just offered very basic generic answers that didn’t help.
Anything you can do to help would be appreciated
Thanks
Rog
I have encountered the problem with the automatic climate control resetting to OFF, and losing my previous settings when I turn it on again. I haven't had those specific other problems but there are at least a half dozen other issues with the system. For example, the setting for the FCW sensitivity are not retained after shutoff (and I'm not convinced the system even works TBH), the instrument cluster display for the navigation doesn't clear after a completed turn, and the setting for "auto unlock on exit" simply does not work.
I've had it to the dealer but they said there is no update for it yet. They were talking to FCA engineering, who acknowledged the problems and said an update would be available in "about a month". That was three months ago. I've checked the UConnect website for an update as of the past week and there is still no update.
sometimes it takes time
Keep in mind updates need to be made, tested, and then published for use - they may have run into other issues as they work to fix what they already know about. That said you should be able to keep in contact with your dealer and with the Jeep Cares team - hopefully they can help you.
Really frustrated with the speed cameras now. Has anyone managed to hide them/turn them off?
When you zoom the map out you can’t see roads or names properly because the cameras cover everything. Come cities here are flooded with the cameras which makes the map unusable.
I have turned off all POIs and speed camera warnings but the map is still littered with camera symbols.
Any ideas?
