U-Connect!
Great Start!!
Now if there was something on how to use the U-connect thing, I could not find a word in the manual on how to use it (not that it matters much cause I don't have a bluetooth phone... "YET" /wink)
Hi there flybynight! I got these instructions from my Dealer. (See Below) I have had the car for two years now, and I still can't get the U-connect to work. Even though I have a blue-tooth compatible phone (Motorola Razor) My u-connect WILL NOT recognize it! When you buy your next phone, go through the menu on your u-connect to see what phone options are compatible with your car. It is limited. We live and learn.. nothing is ever simple.
Operating Instructions
Linking to UConnect™ – Required for “First Time Use” of Each Cell Phone
To complete the pairing process, you will need to reference the cellular phone owner’s manual.
1. Press the Phone button to begin.
2. After the READY prompt and the following beep, say “SETUP.”
3. When prompted, after the voice on beep, say “PHONE PAIRING.”
4. From a list of options, choose “pair a phone” by saying “PAIR A PHONE.”
5. You will be asked to say a four-digit PIN number, which you will later need to enter into your cellular phone.
You can enter any four-digit PIN number. You will not need to remember this pin number after the initial
pairing process.
6. You will be asked to confirm your four-digit code. Do so by saying “YES.”
7. At this point, the system will prompt you to begin the pairing process on the customer’s cellular phone.
This process will vary slightly depending on the cellular phone. Customers may need to refer to the phone’s
owner’s manual.
8. For identification purposes, you will be prompted to give the UConnect system a name for your cellular
phone. Each cellular phone that is paired should be given a unique phone name.
4
To Place a Phone Call
1. Press the Phone button.
2. After system READY prompt and beep, say “DIAL,” (“CALL” on Jeep® vehicles).
3. When prompted, say the phone number.
• A name can replace the phone number if the name has already been entered in the system’s phonebook.
• When calling a name, the driver will say CALL and, when prompted, say the person’s name.
4. The UConnect™ system will confirm the phone number or name and then dial.
To Answer a Phone Call
1. The system will lower the audio system if it is on.
2. The system will ask if you would like to answer the call.
3. To reject the phone call, press and hold the UConnect button until you hear a beep, this indicates that the
incoming call has been rejected.
To Add a Phonebook Entry
2. After system-ready beep, say “PHONEBOOK NEW ENTRY.”
3. When prompted, say the name of the new entry. Use of long names helps the voice recognition and is
recommended.
4. When prompted, enter the number designation (e.g. Home, Work, Mobile, or Pager). This will allow you to
store multiple numbers for each phonebook entry, if desired.
5. When prompted, recite the phone number for the phonebook entry that you are adding.
6. After you are finished adding an entry into the phonebook, you will be given the opportunity to add more
phone numbers to the current entry or to return to the main menu.
• The UConnect system will allow you to enter up to 32 names in the phonebook with each name having
up to four associated phone numbers and designations.
UConnect is a trademark of DaimlerChrysler Corporation. Jeep is a registered trademark of DaimlerChrysler Corporation used under licence by
DaimlerChrysler Canada Inc. Bluetooth and the Bluetooth logos are trademarks owned by Bluetooth SIG, Inc., U.S.A., and are used by DaimlerChrysler
under licence.
Hope this helps!
5
