We have been having problems with our Jeep for about a year and a half. It started with a crank shaft sensor. We have had to replace that thing about 4 times now. Then, the key wouldn't work. Then the crankshaft sensor again. Finally, nothing we changed would make it run. We took it to a dealership. They said the PCM needed changed. So we bought one (pre-programmed) from Flagship One and installed it. Now it's throwing 7 different codes - Flagship One is saying the codes are not PCM related or non-existent. Any ideas?
The codes are:
C2174 (Manufacturer control)
C3064 (Manufacturer control)
P0055 (HO2S Heater Resistance Bank 1 Sensor 3)
C342D (Manufacturer control)
P0123 (Throttle/pedal position Sensor/Switch A Circuit High) <--- this one shows twice
P2172 (Throttle Actuator Control System Sudden High Airflow Detected)
The codes are:
