1 - 20 of 25 Posts
I know it's common for modern vehicle to cheapen out and include a can of fix-a-flat instead of a spare tire. But a compact spare should be standard equipment on a Jeep! (full size spare with same pattern alloy wheel as a low cost option) Stop wasting development money on Easter eggs. Come on, braille on the driver foot rest? Leave out the silliness and put in useful equipment.
They have full sized spares on trailhawks
You can purchase a full size spare. I'm fine with the fix-a-flat. In 15 years of driving, I've only used my spare once and it was in worse condition than the "flat" tire
Agreed, there ought to be a spare. Every time I've had a flat is was catastrophic -- once so hard over a curbstone I dented the rim (my bad), another over a road hazard so when I put air in it I could hear it hissing out. Happened OTW work at 4AM so waiting for AAA would have meant I'd lose a day's pay. I just may get the spare kit, but I admit I like the extra storage space under the rear deck -- I've got most everything I own under there!
I worry about only having one full size spare. Thorn trees are common in my area, I've seen thorns go through tractor tires. Very possible to get more than one flat at a time. Not common on pavement though ;-)
At work (construction/industrial) there are often nails, random sharp pieces of metal and so on.
This is actually quite common across all manufacturers. It isn't necessarily a cost reduction but a weight reduction / mileage improvement. Gets a better EPA mileage for those comparing cars and helps with overall corporate average fuel economy. Jeep will sell the spare separately to those that want it. What I don't like is the way Chevy did it in their cars - Cruze in particular. The base models have a different trunk and fuel tank that the compartment for the spare doesn't even exist.
I thought the no spare tire/fix-o-flat on my Jeep Compass was strange, but we do enjoy the extra room under the rear deck - we use it on vacations and trips for soft items like blankets and pillows.
The best extra thing I bought from the dealer with the Jeep was the extra tire warranty. Two weeks after I bought my Compass, I somehow ran over 2 roofing nails and ruined my left front tire. A new tire would have cost $300.00, but with the warranty, there was no cost for the new tire. It was worth the extra money for the warranty.
If you get the factory towing package it includes a spare tire on a steel rim which they call a "Non-matching Full Size Spare", this is what I have. It can be used longer than a compact limited use spare but it still doesn't seem all that great to me. My first preference is to attempt to remove the nail/object and put in a plug before resorting to the spare. Plug kits are cheap and really not all that hard to install but you must carry one AND a compressor of some sort, plus pliars and maybe even a valve stem tool... so its definitely not for everyone but for a single-nail flat its a very fast and easy option to try (much better than injecting any kind of fix-a-flat goo).
You never end up driving very far on a spare anyways, compact or not, so the only time a full-size spare is probably really "worth it" relative to the odds is when you are off-roading and in increased danger of puncturing a sidewall (unrepairable), or when you are going to be a long ways from home/help. For normal on-road driving, it is much more likely you will pick up a nail or screw in the face of the tread, something you can often pop a plug into and be back on your way (or, inject the can of slime so you hold air long enough to make it to a tire shop). Heck, in many cases I have seen the nail or screw is leaking so slowly you can leave it in place and just air up the tire to limp a few miles further to your home or a shop. No need to mess up the inside of the rim with slime or attempt a roadside plug if its leaking slowly and you are close to home.
This discussion makes me think there would seem to be a strong argument in favor of me rolling my "Non-Matching Full Size Spare" into a corner of the garage and enjoying the cavernous space beneath the cargo floor for all the other goodies I like to carry around (plug kit, combination compressor+jump starter pack, jumper cables, jack, tow strap, tools, first aid, etc). For me just driving 8 miles to work and back in my home area with dozens of friends and family around I could easily call on someone to pick me up and help me retrieve the spare if I really needed it. When going on a longer road trip, I could perhaps roof-mount the spare tire so its on-hand if I got in a bind a long ways from home. Would cost me a little MPG but if it was in one of those aerodynamic cargo boxes it would at least be similarly protected from the elements like it is in the cargo floor. Hmm, I'll have to think about that. Leaving home without anything less than the kitchen sink tends to pain my mind, but there is so much stuff crammed into my Jeep (especially with the winter gear)...
Ok, here goes but this is what I think. Jeeps without spare tires is pure 🏇 ****. Manufacturers are taking away spares because more and more people lack the basic skills to change a tire. In fact the bottom line is the steering wheel is next. Governments across the world seek depend people helpless to survive without assistance. My advice teach your kids to change a tire and think for themselves. I carry an emergency kit and full size spare in my Jeep and I could give a rats ass if it hurts my gas mileage. Just the way I feel folks 😎
They took out the spare to achieve mpg and cut cost, the spare tire kit is still an option when you buy a Jeep its just not standard anymore and lots of Mfgers are doing this
Try to get the factory-installed spare tire kit
Just a bit of advice, if you are thinking of getting the spare tire for your new Compass, either go for the Trailhawk or a Latitude with the $ 245 option for the "Compact Spare" on the Window Sticker. My Jeep was not so equipped, so I ordered through my Jeep dealer in late June - the "2018 Jeep Compass - Spare Tire Kit - 82214638AB." And even with repeated calls to the dealer's Parts Department, and later dealing with Jeep Customer Assistance Center - I did not receive the spare tire kit until early December! (And it was around $ 300!) And I agree with the previous threads, the fix-a-flat and inflator are no substitute for a spare tire. (What if you get tire side-wall damage? Ever try rotating your own tires with no spare and no jack?) (In addition, my local tire shop indicates that the fix-a-flat "gunk" probably ruins the TPMS sensor, requiring replacement, so a $ 10 plug to fix a nail hole will now cost you $ 100.) In any event, I recommend going with a Compass equipped with the spare.
Bad move Jeep-FCA, eliminating the spare tire as standard!
Will a full size wheel fit in the spare location? I plan on swapping my wheels and will just put one of the factory wheels in there as a spare if it will fit.
May be worth pointing out this is the least likely thing to happen to folks who don't leave the pavement.
Well if you don't have a jack and a couple jack stands odds are you are not the type of person to rotate your own tires anyways? I dunno, I never use the spare when I'm rotating. Doesn't seem any easier than putting one or more corners on a stand for a couple minutes.
A plug is not the same as the slime. A plug is as simple as jacking up the corner with the flat, pull the nail out with some pliars, rasp the hole clean and then jam a plug with the rubber cement on it into the hole (the pea-sized drop of glue on the plug will not hurt your TPMS sensor). Air the tire back up and drive away. If all goes well it will hold air for life, no reason to go to the tire shop at all, and you don't have to wrastle the lug nuts off and even better you don't have to wonder if you put the lug nuts back on tight enough when you roll away on your spare. And its only about $4-6 for a plug kit, if you buy one at $10 you overpaid :p
Those cheap tire plug kits aren't meant as a permanent fix, they're meant to get you back on the road for a real tire patch. The only true tire plug/patch that lasts the life of the tire is done by removing the tire from the rim and plugging/patching the tire from the inside.
Yes. Plug it, get to a tire shop and get a $20 patch. Works for me.
Will a full-size wheel fit in the spare location? I plan on swapping my wheels and will just put one of the factory wheels in there as a spare if it will fit.
I just got a flat last week. 4 am BS w/ no spare! Luckily the tow company had a heart and sent the wrecker right away (my wife and kid were in the car).
I now have a full-size spare in the back, scissor jack, and lug wrench... Now that I've done all that I'll never get another flat. Murphys Law
1 - 20 of 25 Posts
