any sugestions? my wheel is stuck the the hub on my '07 limited and I can't get it off.
Honesty, give it a good it with a rubber mallet where the rim and tire meet. Go side to side topto bottom. That should do the trick. If that don't work try grabbing from behind the rim and pulling from side to side.
Thank you for the help and suggestions. I did finally get the tire off after giving it a few swift kicks.
My old VW GTI had that problem. My mechanic told me to put a little grease on the back of the centre hub of the rim. This helps the rim from "sticking".
I have been doing this for the past 15 years and have never had a problem getting a rim off.
Bolton
