I took my Jeep Compass back to the dealer when the noise started its now louder and winds down when you let off the gas starts around 40mph I can her it over the radio I drove my friends hers is also a 2011 and IT DOES NOT MAKE THIS NOISE The dealer says well its normal ITS NOT what do I do its under warranty and Ive only had it since may 31st please help!!!!
Hello,
Sorry to hear you're having some troubles with your dealership. Your description of your whine and when it happens is a little lacking in terms of specificity. It only happens at that speed? Does it change when you turn left or right? Does it happen coasting at speed in neutral? Have you jacked up the vehicle and checked for play in the wheel or components? Is there a change when you're breaking? When did you last get a wheel alignment done? Happy to help you if I can, but I'm lost without more info.
Good Luck! :)
