1 - 18 of 18 Posts
2019 Jeep Compass Latitude
What lights did you use, and where did you buy them?
I actually used a cheap set that came from pep boys. They were 15 dollars. They came with a threaded housing and I drilled directly into the grill and screwed them in. Then I purchased a drl controller from amazon and wired them directly to the battery.
Thanks.
How is the KO2 tire noise on the highway...much more than stock? Also did you have any MPG drop with them? I am wanting to put a set on my truck when the factory ones give out. Thanks!
The noise is noticeable at 35+ mph but it’s not annoyingly loud. I would recommend.
Looks great! I was actually thinking of doing something similar with the amber LEDs. Do you have any close up photos of them?
What size tire did you end up with? I would like to go just a bit bigger with mine... also what lightbar did you install on top?
Discussion Starter #10
I messaged you back but I’m responding here for others to see as well! Tires are 225/65r17 and fit without a problem. And the light bar is a 30in curved single row rough country. I wired all f my lights to toggle switches under the steering wheel. I will post pictures on that shortly.
Discussion Starter #11
13546
wow love this. can I double like this ?? lol
sweet wheels and tires, and from what I'm reading you went this route with no spacers or lift?
what wheels are those? I'm thinking if I decide to keep this car might try something similar (still on the fence at the moment with the oil burning - arrrgg).
cheers
*Edit - just saw the title XD wheels with KO2 tires.
SWEET!
Hey just wanted to ask which model compass is that?
Looks like a trailhawk but wasn't sure.
Did you change part of the lower front bumper skirt?
Discussion Starter #17
Ah, very nice! Sorry, last question, what brand of spacers? And so far it rides good?
Love the questions. Add me on Instagram @TrailhawkCRF for pics! The spacers are random ones from Amazon for the renegade actually. I went with the highest rated ones. Rides great! Really took away the skateboard look.
Any rubbing at all with no lift? You wouldn't happen to know the backspacing on those wheels would you? And how close it it, would a 1" wheel spacer work?
Thanks.
1 - 18 of 18 Posts
