What is the Biggest tire size without a lift and without any rubbing that can fit on a 2017+ Jeep Compass?
Thank you for the quick response!!
at the 235/60/18 the overall diameter comes in at 29.1, should i be worried? i know everyone says 28.4 fits well..You'll probably have minor rubbing at full lock. A wheel spacer may be needed, but I think the 18s have enough clearance/offset to not need them.
A 225 would definitely fit better and probably have no rubbing. The extra 10mm width is minimal; that's 1cm. If you're worried about fitment, go with the 225.at the 235/60/18 the overall diameter comes in at 29.1, should i be worried? i know everyone says 28.4 fits well..
I could go 225/60/18 but want the extra width in the 235. Decided on the Yoko Geolandar a/t
Trailhawk?...I'm running 235/65-17 which is 29" and they have minimal rubbing at full lock...
Nope, 2018 Latitude w/1.5" wheel spacersTrailhawk?
Hello there did you get the 225/70r16 ? Is it working out fine with sand and deflating? Any rubbing?I bought some aftermarket rims that are 16" diameter, but I haven't installed them yet. I also want to air down for offroading. If I ever get mine installed, I'll report back.
I have the Trailhawk. Since you only have a little rubbing and the Trailhawk sits an inch higher, do you think I‘d get away with the same size (235/65r17) and no rubbing?Nope, 2018 Latitude w/1.5" wheel spacers
Most of my rubbing is on the front/rear of the fender liner. So no, being higher won't help with that. However, if you go with a smaller spacer, you probably won't have as much or any rubbing. I was running 1.5", so I'd try 1.25" or even 1".I have the Trailhawk. Since you only have a little rubbing and the Trailhawk sits an inch higher, do you think I‘d get away with the same size (235/65r17) and no rubbing?
Btw, stock Trailhawk sits on 235/60r17 here in Germany… There seems to be a little room left….
I was thinking of no spacer at all? Since it’s the same width as my stock size (235), it should be fine, right?Most of my rubbing is on the front/rear of the fender liner. So no, being higher won't help with that. However, if you go with a smaller spacer, you probably won't have as much or any rubbing. I was running 1.5", so I'd try 1.25" or even 1".
Hey I have a 18 compass and I’m giving it a 2inch lift and wventually doing a new suspension to how I’m pretty sure I have a 225/65 17/18 I think how much bigger you think I could go cause I wanna put some beefy off-road tires to give me a bit more clearanceI'm planning on running 225/70/16's on my Compass Sport. Wrangler SR-A's. They'll be here next week so I'll report back. I don't really anticipate any issues. The wheel wells are massive with the current 215/65/16's.
As for fuel economy, it really depends on your driving habits. If you do a lot of city driving, you'll likely see a bit of a MPG drop off - but really not that noticable. A lot of highway mileage and you likely wont notice at all.
There's plenty of studies on this subject. I can't post links yet or i'd send one over.
I am on 235 70 16 without lift.Has anyone tried 235/60 R16 tyres AT tyres. Unfortunately this is the only size available locally that is closest to the original 225/55 R18 that I have presently.
Will these fit without any rubbing. I am concerned about the width since these are wider than standard size.
I have original Jeep Steel wheels in the 16 Inch 6.5 J size which I would use for the 235/60 R16 tyres.
I have installed 225/70 R16 (diameter 28.4”) on 2019 jeep compass and they fit perfectly fine.
No lift and No rubbing.
Nice wheels. ]
