So I was having trouble diagnosing issues with the front passenger side tire of my 2014 2.4 sport , I’d already replaced the bearing on that wheel which was definitely bad , but was still having issues so I did the jack test , I jacked it up and shook the wheel and the only direction I got any play in was up, so I went looking for the ball joint and turns out you have to replace the control arm , but my question is why isn’t there a front upper control arm? only option I keep seeing for the front right is lower control arm, so is this what I need to get or is there a different problem that I’m not aware of?
