How do I open the panel containing the OBD2 port? I find many explanations as to where it is located but no mention about how to open it gently.
2012What year is your Compass?
Thanks.... as I said, I know where it is. I want to know how to open the panels without damaging the plastic.It's under the dash, driver's side, to the right of the hood release.
I read the manual first. I scoured the internet second. I reached out here third. Still, no direction as to how to pop the dash panels so as to access the port. I dont want to just start prying.I don't think I've ever seen a car where you have to remove a panel to access the ODBII port, are you sure that's necessary? (Like Eugene, I wouldn't know on a 2012, I have a 2nd gen)
Have you looked in the owner's manual? If no manual in your glovebox you can get the manual online for free. Also could try youtube.
What a guy. Thanks for the solid.You have input from the forum. Posting your problem is not going to resolve your issue ... do something.
Perfect advice and support! Thanks so much!!!Look at this video, no panels to remove, just up under the edge of the lower dash panel...https://www.youtube.com/watch?v=Pg7fuZv7iGY
