On my monthly vehicle health report it indicated that there was a recall issued. Clicked on the link and it states that it is for oil consumption on the 2.4 and will be fixed with a computer flash lol
yeah same here 2018 trailhawk .. but guess what? I had a new engine put in 3 months ago at 15.5k miles and today I Checked and I'm completely dry At 17k in my case even a brand new engine did absolutely nothing.I own a 2018 compass limited and have had the issue with my Jeep starting before my very first oil change, here we are 2 yrs. later and my compass is finally in the shop having a new engine put in. I’m just disappointed that it took this long with many visits to the dealer to finally fix it. I almost feel like they waited long enough that it wouldn’t qualify for the lemon law due to mileage.
Yes, I just had mine done. It explains it all if you look it up. It has to do with changing the timing of the engine. Mine went smoothly and all is running fine. I did not have much of an oil issue to begin with but I will keep you posted.On my monthly vehicle health report it indicated that there was a recall issued. Clicked on the link and it states that it is for oil consumption on the 2.4 and will be fixed with a computer flash lol
Did they advance or retard?Yes, I just had mine done. It explains it all if you look it up. It has to do with changing the timing of the engine. Mine went smoothly and all is running fine. I did not have much of an oil issue to begin with but I will keep you posted.
Actually, my engine made kind of a ‘dieseling’ noise at low acceleration, it seems to have fixed that.Yes, I just had mine done. It explains it all if you look it up. It has to do with changing the timing of the engine. Mine went smoothly and all is running fine. I did not have much of an oil issue to begin with but I will keep you posted.
I have a 2018 Jeep Compass Sport with just over 27,000 miles. I have been adding a quart of oil every 1,100 to 1,200 miles since I purchased it last year with 18,000 miles on her. I have been continuously daily checking the oil, so I have not seen any low oil pressure lights on the dash. Of course the dealer says anything over 1 qt. per 1000 miles is "normal" oil usage.Yes, I just had mine done. It explains it all if you look it up. It has to do with changing the timing of the engine. Mine went smoothly and all is running fine. I did not have much of an oil issue to begin with but I will keep you posted.
Pleeeze oh pa-leeeze keep us posted!I have a 2018 Jeep Compass Sport with just over 27,000 miles. I have been adding a quart of oil every 1,100 to 1,200 miles since I purchased it last year with 18,000 miles on her. I have been continuously daily checking the oil, so I have not seen any low oil pressure lights on the dash. Of course the dealer says anything over 1 qt. per 1000 miles is "normal" oil usage.
Today I got a letter from FCA addressing this issue "Recommending the following improvements" to my compass, they are going to change the current engine calibration strategy by reprogramming the PCM. How this will stop an engine from burning oil is to be seen.
As has been said earlier, at least they are addressing the issue. My appointment has been made, we'll see what happens.
Ed
just a side note, the minimum usage is 1qt per 2,000 miles Your dealer should be doing an oil consumption test also, before the warranty runs out...I have a 2018 Jeep Compass Sport with just over 27,000 miles. I have been adding a quart of oil every 1,100 to 1,200 miles since I purchased it last year with 18,000 miles on her. I have been continuously daily checking the oil, so I have not seen any low oil pressure lights on the dash. Of course the dealer says anything over 1 qt. per 1000 miles is "normal" oil usage. Ed
NO IT'S NOT! Sez who? Sez them. It's acceptable only by the standards they set. Frankly, 5000/quart is what I'd expect from any engine under 200,000 miles. Granted a brand new engine might use a quart in its first 1000 miles, that's to be expected until it's thoroughly broken in. After that it shouldn't consume, leak, or otherwise use any oil at all. My 2018 Compass (bought new) was the first vehicle I ever owned that couldn't get between oil changes without adding some. I've taken most vehicles over 100,000 and several over 250,000 miles: never did I have to add more than a quart and that was rare -- might have been a short fill to start with.SUBJECT: Engine Oil Consumption Guideline 2017 model year from TSB 09-007-15 (should be the same for 2018 models)
The accepted rate of oil consumption for engines used in the vehicles listed above is 1 quart (0.946 liter) in 2,000 miles (3,200 km) for the 1st 50,000 miles (80,467 km). For vehicles with more then 50,000 miles (80,467 km) the acceptable oil consumption for engines is 1 quart (0.946 liter) in 750 miles (1,207 km).
I'd call that marginally acceptable. You can at least make it between oil changes without adding any.At 12.5K miles and a year and a half of ownership on our 2019. I have been checking the oil level every month and from the very beginning the truck has used oil at a rate of around 5K miles per quart. I did not see much of an initial higher break-in rate.
I'll take it...I feel so sad for the owners that get only a few K. So glad I did not buy the used 2017 model I was looking at.I'd call that marginally acceptable. You can at least make it between oil changes without adding any.
I wonder if many of the 2017s & 2018s that are arriving on used car lots could be oil burners -- people just gave up on them and traded out. I'm still not sure if maybe FCA got their act together by the third model year or if the oil consumption problem persists.I'll take it...I feel so sad for the owners that get only a few K. So glad I did not buy the used 2017 model I was looking at.
Can you post some links for reference?Yes, I just had mine done. It explains it all if you look it up. It has to do with changing the timing of the engine.
Interesting.Actually, my engine made kind of a ‘dieseling’ noise at low acceleration, it seems to have fixed that.
HAAAAAAAAAAAAAAAAAhahahahahahahHAAAAAAAAAAAAAAAAAAAAAAAAAAhahahahahha.....ah.ah....ah ah.... it hurts... the mere idea... FCA got their... HAH... oh... good one! So hilarious...I'm still not sure if maybe FCA got their act together by the third model year or if the oil consumption problem persists.
I'm sorry if I made you choke on your corn flakes.HAAAAAAAAAAAAAAAAAhahahahahahahHAAAAAAAAAAAAAAAAAAAAAAAAAAhahahahahha.....ah.ah....ah ah.... it hurts... the mere idea... FCA got their... HAH... oh... good one! So hilarious...
Jeep Cherokee Oil Consumption TSB/RecallOfficialMopar said:Hello, the oil consumption concerns are caused from vacuum being created in the cylinders during deceleration. Software changes the events, internal to engine, that lead to creation of vacuum.
If you need any help setting up an appointment, feel free to let us know.
Kaitlin
Mopar Cares
That makes more sense than anything else I've seen.I just read the following explanation, on the Allpar forum, by an FCA representative (the equivalent to @JeepCares on this forum) about how the software update addresses the issue:
