On my monthly vehicle health report it indicated that there was a recall issued. Clicked on the link and it states that it is for oil consumption on the 2.4 and will be fixed with a computer flash lol
Interesting.On long trips, several hundred miles on Interstate Highways at steady 70 mph, no oil consumption noted. Doing same or shorter distance around town (over several weeks), with suburban type "stop and go" traffic, is where I note my oil consumption.
Dealer went ahead and flashed mine without my permission when it was in for a faulty seat latch replacement. When I asked them what the flash does, they had no idea. I wasn't planning on getting it done because mine only uses a liter every 4000km or so. I doubt it does anything useful as I can't imagine they could mess with the vacuum in the cylinders without compromising how the engine runs. Probably just turns on the change oil light sooner or something like that.Would guess it’s a little in vain and wouldn’t expect a flash to change oil consumption but curious is anyone in Canada have this recall?
I'll be curious to know if the flash changes performance or anything else.Dealer went ahead and flashed mine without my permission when it was in for a faulty seat latch replacement. When I asked them what the flash does, they had no idea. I wasn't planning on getting it done because mine only uses a liter every 4000km or so. I doubt it does anything useful as I can't imagine they could mess with the vacuum in the cylinders without compromising how the engine runs. Probably just turns on the change oil light sooner or something like that.
Also we did a 3000km road trip last year and it seemed to burn about the same amount of oil on the trip as around town.
same here, curious to see what happens with others ... we also got a notice, but I don't plan on bringing it in anytime soon ...I'll be curious to know if the flash changes performance or anything else.
Apparently certain conditions cause the engine to draw a vacuum that must suck oil into places it shouldn't go. The software is supposed to reprogram the engine to avoid this. @georgef turned up this post on another automotive thread: Jeep Cherokee Oil Consumption TSB/Recall Sounds credible to me, but I'd love to hear from those who have had the update done. Did it cut oil consumption? Was there a trade-off in performance?Just got this in the mail today and was just wondering myself.. What does this recall fix exactly or what does it do? Any issues after the reprogram? Anyone here know?
I haven’t heard anything about a recall but my Jeep has been shutting off randomly and I think it’s due to low oil without any indication it was low. I went In for the diagnostic today as well as an oil change and they plan on running a new update in the software that came out in September. Not sure if this is the “recall” but I think it might be the hush hush update to fix it. I’ll let you know if this “update” fixes my oil and doesn’t make my vehicle shut off in the middle of the road.Would guess it’s a little in vain and wouldn’t expect a flash to change oil consumption but curious is anyone in Canada have this recall?
An interesting quote from Mopar Cares on that thread:@georgef turned up this post on another automotive thread: Jeep Cherokee Oil Consumption TSB/Recall
So maybe its not blow-by and the PCV system as I previously thought. Just excessive vacuum in the cylinders during decel when the fuel is cut off? They could easily adjust that with a software update. If its mainly a condition that occurs during deceleration there would not necessarily be any reason to imagine it would impact performance or power output.Hello, the oil consumption concerns are caused from vacuum being created in the cylinders during deceleration. Software changes the events, internal to engine, that lead to creation of vacuum.
If you need any help setting up an appointment, feel free to let us know.
Kaitlin
Mopar Cares
The problem with it shutting down due to low oil level can be easily prevented by checking the oil on a regular basis -- if it is low, add however much is needed. This is standard operating procedure for a brand new engine or a very old engine, albeit for different reasons.I haven’t heard anything about a recall but my Jeep has been shutting off randomly and I think it’s due to low oil without any indication it was low.
I disagree. My oil wasn’t old, nor did my sensor go off. I don’t think I need to check my oil when I recently had an oil change and it’s a fairly new vehicle. I paid for an expensive vehicle with a sensor. Everything on my dash is showing good and it runs perfectly smooth until it shuts off. Ive never had an oil issue before. I also drive it only once a week. But yes, I hope it also solves this problem. It’s not safe. Period.The problem with it shutting down due to low oil level can be easily prevented by checking the oil on a regular basis -- if it is low, add however much is needed. This is standard operating procedure for a brand new engine or a very old engine, albeit for different reasons.
I hope the update solves your problem.![]()
The age of your oil has nothing to do with it. The oil change light (if that's what your talking about) factors in miles driven and your driving conditions to give you an approximate warning that it's time to change (not fill) the oil.I disagree. My oil wasn’t old, nor did my sensor go off.
You always need to check your oil, and for a variety of reasons. Engines can leak oil, mechanics can accidentally (or intentionally) short your fill after a change, or in our case the engine can consume it because of a flaw in the software design. New engines almost always use some oil, probably up to 10,000 miles. The problem with the Compass is that it is using way more than an owner would normally expect.I don’t think I need to check my oil when I recently had an oil change and it’s a fairly new vehicle.
I don't believe any Compass comes with an oil level sensor. I've had cars that have such a sensor, but not my Compass.I paid for an expensive vehicle with a sensor. Everything on my dash is showing good and it runs perfectly smooth until it shuts off. Ive never had an oil issue before. I also drive it only once a week. But yes, I hope it also solves this problem. It’s not safe. Period.
Yes. My Jeep Compass is equipped with an oil level sensor. It has gone off once, I checked, and I brought it in for an oil change the next day. The Jeep was going on 10,000 km without an oil change (pure synthetic oil) and it was all fine. I didn’t even KNOW that Jeep compasses had issues with oil consumption, or I wouldn’t of bought it. It’s unfortunate your compass doesn’t have a level sensor. And no, the age of the oil doesn’t have anything to do with it but if I bring my Jeep to a dodge to get an oil change, you would think they put enough oil in.The age of your oil has nothing to do with it. The oil change light (if that's what your talking about) factors in miles driven and your driving conditions to give you an approximate warning that it's time to change (not fill) the oil.
However, I agree that it would be a real good idea, especially considering the design of these new engines. Presently, the only way to know your oil level is to check the dipstick -- that's why it's there and as far as I know every car has one.
The reason your engine shuts down is because, besides lubrication, it also uses the oil to operate the valve lifters. If there's no oil they can't open and your engine stops -- it's about the same as running out of gas.
After a couple of years of posts on this site, probably lots of complaints, and repeated denials from FCA, they have finally admitted the problem and they are doing something about it. Time will tell if this update solves the problem.
Agreed, I think most dealers are honest, but some aren't and sometimes a mechanic gets distracted and short-fills accidentally.Yes. My Jeep Compass is equipped with an oil level sensor. It has gone off once, I checked, and I brought it in for an oil change the next day. The Jeep was going on 10,000 km without an oil change (pure synthetic oil) and it was all fine. I didn’t even KNOW that Jeep compasses had issues with oil consumption, or I wouldn’t of bought it. It’s unfortunate your compass doesn’t have a level sensor. And no, the age of the oil doesn’t have anything to do with it but if I bring my Jeep to a dodge to get an oil change, you would think they put enough oil in.
