On my monthly vehicle health report it indicated that there was a recall issued. Clicked on the link and it states that it is for oil consumption on the 2.4 and will be fixed with a computer flash lol
I hope you are not referring to me, I have never once not been crystal clear in my posts in saying that the V6 Cherokee is superior. Oil consumption issues are virtually unheard of in the 3.2 V6, and FWIW it uses a more traditional 5w oil as well instead of a 0w like we have in the 2.4Some on this site have been touting the superiority of the Cherokee because it wasn't having this problem.
May have been others with the 2.4. I had no one particular in mind. It may not even have been on this site but this is where I am rather frequently.I hope you are not referring to me, I have never once not been crystal clear in my posts in saying that the V6 Cherokee is superior. Oil consumption issues are virtually unheard of in the 3.2 V6, and FWIW it uses a more traditional 5w oil as well instead of a 0w like we have in the 2.4
Have you had the recall done? Like you, I'm a skeptic, but some are saying it actually worked for them. All I can say is that my 2018 used oil and my 2019 does not. They must have made the change at the factory before issuing the recall.It’s not just the Compass. I have a 2016 Jeep Cherokee with the garbage 4 cylinder tiger shark engine. They changed there parameters now so when I had my oil consumption test there was a tiny speck of oil in between the lines after 1500 miles. They said that this is normal lol. I doubt this software thing will help an engine that burns oil. I go through 5 quarts of oil between oil changes. It’s terrible and Jeep needs to own up to it and issue a recall! There name is mud until they do.
IDK if a Carfax report would show everything. Seems to me a lot of people with problem vehicles have found ways to avoid Carfax reporting.I wonder how you could check for this issue on a used Jeep vehicle? Go to a dealer and have them run the service log to see if there are any complaints, look for excessive oil spilled around the oil fill cap, or get a 3 day return contract and go for a 500 mile test ride?
Carfax provides fairly good maintenance logs, depending on where the PO had stuff done. Dealer records are there, as well as those for some independent shops. Getting dealer to pull logs is probably a good thing to do. If there was an issue and the PO tried to get it fixed under warranty - you'd see either notated or at least more frequent than expected service visits.I wonder how you could check for this issue on a used Jeep vehicle?
You say this all the time and I always have to chime in with a reminder that your sample size of two cars is far, far too small to draw any such conclusions from. Very, very few of these cars rolled out with the oil consumption issue. It feels like a lot because those who have those issues are very vocal, but the Compass is selling by the tens of thousands of units, most have no oil consumption issue. To get one with oil consumption issues was to win an unlikely lemon lottery. You maybe won (lost) the lottery with your first car and then prevailed with the second Compass because the overwhelming odds were always going to be that it wouldn't be an oil burner.All I can say is that my 2018 used oil and my 2019 does not. They must have made the change at the factory before issuing the recall.
For God's sake please do not do such a foolish thing. You think you are smarter than the TEAM of engineers that designed these engines and spec'd its oil requirements?? The oil in this engine is not just for lubrication, the valves are hydraulically actuated by the engine oil and it uses variable controls there for the Multi-Air system on the intake side, its a really high-tech thing and you should not be compromising its performance by going off-script with what viscosity of oil should be in there. Circling back to lubrication, a lot of places in this engine the "thin"* oil is sprayed almost as a mist and if you go putting "thick"* oil in there those lubrication processes may not work properly, you risk excessive wear on your engine and reduced performance of the multi-air system, not to mention your warranty. And why, because you think that they would not have ran the cheaper and more readily available 5w oils in this engine if they could have?? Nonsense.When the next oil change is due (top ups, too), it will be 5W-30 full syn oil. They "recommend" 0W-20, but that's a CAFE (fuel economy) thing.
There IS a cabin air filter, not sure what you mean there.Same reason not even a skinny spare tire or 4 ounce cabin air filter is standard.
Use care when calling people fools. Are you aware that substantial testing of these engines was done with 5W-30, and they went all the way to 20W-50 for the "thick" oil in testing? Or that there's anecdotal evidence from multiple sources that 5W-30 reduces oil consumption without causing problems?For God's sake please do not do such a foolish thing.
linkThere IS a cabin air filter, not sure what you mean there.
No, I bought one with a factory tow package and a full sized spare. You're simply making unjustified assumptions.You bought a cheaper lower-trim model with fewer upgrades or extras, so you saved money on your purchase price up-front and get slightly better fuel economy carrying less weight, so quit crying about it.
That's quite the understatement. It was done by two staff members and a research assistant of the Southern Illinois University Dept. of Automotive Technology, with the support and cooperation of FCA.group in Illinois was testing canola oil in these engines or anything else
Limited probably includes it. And, I'm pretty sure the "Air Cond ATC w/Dual Zone Control" option does, too. Here's a link to a JK Wrangler thread about the lack of cabin filters. I ran across a similar one for the Compass, but can't find it right now.I have a replacement cabin filter sitting in a box, going to be interesting to see if my Limited already has one in there or not when I open it up.
Balderdash! That's like the bank establishing an acceptable level of embezzlement!. . . FCA guidelines are 1qt/2000 is acceptable . . .
I don't think I've ever had dealer work done where they didn't screw something up (not just Jeep). When I had the W20 done, they helpfully overfilled the rear tires (all pressures were correct when it went in). The pressures are on the B pillar, how hard is it to open the door so you know what you're doing?(I was a bit apprehensive of the dealership's work quality, as this is how the dipstick appeared when I opened the hood upon returning home. Maybe not fully inserting the dipstick was part of the solution?)
Thanks for checking back. If you read my previous posts I was definitely suspicious that a software update was going to fix this but you and others confirm that apparently it is working.I own a 2018 Compass (2.4L) and had the PCM update per W20 Customer Satisfaction Notification performed in early February. After driving over 1,000 miles since, I for the first time did not notice any change in the oil level from the dipstick since the update. (I had dealer perform a oil change and filter change at same time.) In the past, I was adding about 1/4 of a quart every few weeks. I am hesitant to say this, but in my case the "Reprogram of Powertrain Control Module" so far seems to have worked. (I was a bit apprehensive of the dealership's work quality, as this is how the dipstick appeared when I opened the hood upon returning home. Maybe not fully inserting the dipstick was part of the solution?)
Yahoo...this is great news. Hope this holds true for the rest of the oil consumption crowd! Wonder what they specifically changed in the engine to achieve this miracle?"After driving over 1,000 miles since, I for the first time did not notice any change in the oil level from the dipstick since the update."
